Need help with 10R Stager
Hello, i installed a 10R stager on a 2018 F150 engine. The engine itself is installed in a older swap vehicle but shouldn't matter.
The problem I'm having is that when I press on trans brake button and i rev it, it goes into 2 step and after 2-3 seconds it closes the throttle and after that the trans neutralizes. I have to shut off and reset codes(even if it doesn't have any) for it to shift again.
I have already disabled all codes it tells me too in the instructions.
Any help would be appreciated.
There is a a coil test under the (spark dwell) tab that needs to be raised.
Raised or lowered? As i understand the description it would have to be higher than the 2-step RPM
