Results 1 to 6 of 6
Thread: s197 SC vct schedule mode disable
    Hi
    vct schedule mode disable this horrible issue kelling me
    its comming in WOT after 7k rpm when all camshaft read zero and mapped point go 0 table
    oil pressure read 99 psi to 94 psi
    oil weight use amsoil 5w50 and in this log use 20w50
    i was recorded wot in big pulley and not see this issue but in another small pulley the issue in vct schedule mode disable comming
    what causie get this problem and anyone can give me advice how we can check error camshaft and fix it
    oil 20w50.hpl
    Any one ��
    install patch for rpm
    Patch applied
    Oct 2016
    Poland
    1,761
    Ok, to some reason you are hitting exh temp control and cyl pr. limit but not sure this will trigger vct to disable.
    Other then that it might not be where you command it - cant see a tune to tell. Both banks are close so in position.
    Not sure by any means but it hitting Cylinder Pressure limit may very well be contributing to that issue. I noticed when tuning my S197 any time I hit any limiter (torque trunc, cyl pressure) the car would not go into PE. I'd recommend maxxing that table out.
