Yes it is wrong if you have a returnless non-FPR vacuum referenced regulator. If you have the fuel filter that incorporates the FP regulator it is not Vacuum referenced and should have a dynamic IFR range. If you did not change the fuel system then do not change the IFR table. To clarify yes the FPR vacuum referenced would have a steady IFR.
No MAF airflow and inj does not match tune log 2.JPG Second log off the ramps referenced.... NO MAF airflow reporting, that is a problem and your tune file it is set up as blended mode but the MAF is not failed with the 0 reported airflow?
Injector flow is not consistent with your table either.
I hope you get this sorted out.
Good luck.
