4.8 with rattler cam input
i was wanting some input on this tune,its the first ive done. 04 silverado 4.8 with rattler cam and valve springs. truck runs good but is lacking on power.papoitrucktunereducedtimingchopmoreair.hpt
Depending on what fuel you are using, you can likely add a couple more degrees timing and disable burst knock for some more performance. However, changing the rear gear from 3.42 to 4.10 and adding a higher stall torque converter would really help performance.
thank you,ill give it a try!!
