Hey all. I finally got my 1990 suburban with a 6.0/4l80e swap started for the first time last night. Took it on it's first drive this afternoon. List of drivetrain mods are as follows:
Engine:
- 2002 6.0 short block
- Truck Norris cam
- 862 heads
- TBSS cathedral port intake (not a truck intake)
- 12679524 87mm throttle body with X-link
- 12613412 50lb injectors
- LS7 MAF in 4" tube with honeycomb straightener
- Walbro 255 pump
- Corvette filter/regulator
- 40 gallons of 93 octane
- new front O2 sensors, rears deleted
- Stock style manifolds, dual 3" exhaust (stops after mufflers, will go all the way back eventually)
Trans:
- 2002 4l80e
- Jasper rebuild about 7k miles ago
- stock converter
Harness/PCM:
- 2005 Silverado 1500 PCM, harness, TAC, pedal, etc.
Based on a lot of searching, I made a few initial changes:
- Scaled throttle body area
- Updated injector data
- Corrected IAT for LS7 MAF
- Lowered stoich to 14.1
- lowered cranking VE by 10%
- Raised idle spark advance to 21 degrees and smoothed
- Lowered over/underspeed adaptive idle tables by 50%
- Requisite swap DTC purge
It starts, runs, and drives but I obviously have a long way to go. I'm currently running speed density only because I haven't found a good source for LS7 MAF data yet, and I want to get the VE tune done first.
I took a few logs today and I don't think they provide a good consensus on fuel trims. Maybe they're just too far out of whack?
TL;DR
Would someone mind giving this a review and recommend next steps/ point out any errors I'm making? I'm still early in the learning process.
2023.02.20 - Suburban working tune after injector, MAF, VATS, DTCs, etc.hpt
2023.02.21 - 1 Cold start no changes from last night.hpl
2023.02.21 - 2 Drive to get gas.hpl
2023.02.21 - 3 Backroads cruise.hpl
2023.02.21 - 4 Some highway.hpl
