could someone look this over please? Ive been having issues with it running super rich, then on decel its pretty lean. a little help fellas...please
Post some info on your car..mods, etc
370 11.1:1 compression
f13 112
ls6 intake and heads
tr6 plugs, ported TB
lid
9" w/ 3.89s
might wanna try logging commanded afr next time too nino lol
I still say your VE table is just too jacked up at this point to make much sense of things.
Just looking at your STFT you can see your nearly 40% overfueled in some areas.
damn it..i knew something was missing Ill see what I can come up with then. Thanks guys.
yeah chances are your VE is off from those other injectors
Sulski Performance Tuning
put your transient fuel to stock as well
ok, have a look at this. i put the stock ls6 timing and ve tables in and did raf again.
I agree, just do some good long logs of your AFR Error % and slowly but surely it should come back in line....Originally Posted by WS6FirebirdTA00
I sorta kinda got him on the right path last night.
ill get a log done today. im about to do raf since i get to go into work late today I also just ordered my LM1! Thanks again Bill!
not a problem nino...hit me up when you get online later.
