Originally Posted by
mourat
Just wanted to report back, that discrete shift assignment low/med/high does not do what is intended. I will try turning upshift adapt off, but even after resetting learned values, setting "high" threshold values to 100 and low and med between 10-50ish or so. Then setting the preset value of number "2" under preset to 250 psi for say 1-2 shift. Does not actually preset to 250 psi even though you have exceeded the 100tq value. If I set all 3 values under preset to 250 psi it makes a difference, but assigning the values appears to be doing something along those lines but not 100%.
I will play some more with that, but it feels like the TCM still tries to hit it's "time to complete shift" target but using a discrete torque value instead of a varying one. So tomorrow I will also adjust those tables to be more inline with what I'm doing in discrete+presets.
I have everything shifting just the way I want, but it would be nice to see discrete working as we hope. So either timing table, or turning adapt off completely should help to better understand what the ECU is doing without the adapt variable. What I really was hoping it would do, is correlate to the pressure preset values of 0,1,2 which it does not appear to be doing :(
