2005 GTP swap in 1983 RX7
Hello all,
Hopefully I don't get bashed to hard, but I need some info.
I'm currently swapping out my old rotors for the L32 out of my 2005 GTP.
I have a T5 with a metric bolt pattern. I don't plan using abs, air conditioning, or power steering. I'm fabricating in the GTP dash into the 7 and going to use the GTP's wire harness.
My question is with hptuners can I mod the pcm to run without the BCM, Abs, power steering, and air conditioning system? I should have the swap done by mid August so any information will be helpful. Thank you much.
