well got injectors in and added pcv system now right and left banks ltft dont match at idle off by 6 to 10? also aint sure bout this pcv system yall got any suggestions
Catch can system?
Venting to atmosphere as in breather filter? If so that's why your running lean now - breather has created a vacuum leak via letting more air into the crankcase during normal operation - just correct via MAF calibration and add a touch to the VE table to compensate...
]alright buddy I'm back , the owner of the shop went on a vacation so I had to work the office but he is back and I dug out the dyno , so I'm ready to get back after it. should my stoich a/f ratio should be the same number for the whole table?? and us the pe multiplyer to get down to 12 to 1 or so at wot???
seems very fat
and I think I'm gonna need that ls3 maf and since I'm using my dyno I need to set a rev limiter of some sort any recommendations?
and I caint get my wot af error graph to populate
Post log/layout
Your air/fuel ratio commanded channel isn't logging for some reason? It's just blank... I'd try deleting and re-adding that one to the channels list
nope still blank
well shit how does that happen it was there and now its gone?
Not sure
i sent somethin to hp support maybe they know
but i need that channel fer wot tuning
Or you can set your WB up as lambda and use EQ error instead
not sure i know that way
think im gonna start a new thread this one to long
You can, but the problem is we ask you to try something or to post something and instead get 10 posts that are totally out in left field of things being done that we know aren't likely to help. That makes it tough to help.
