Problem loging AEM 30-0333 wideband with the MPVI internal logging.
Works fine when using a PC. Does not log the channel when using the interface logging funtion.
Channel config loaded in the interface and log file:
Attachment 63093
Attachment 63094
Attachment 63093
Attachment 63094
How is it connected?
If it's connected via the OBD port then your channel setup is wrong. You need to add "WB EQ Ratio 1 (SAE)" to the list of channels you're logging (make sure it's the one for the wideband, should be the only one . That will be the wideband. No need to mess with MPVI inputs, transforms, etc. Just log that one thing and that's it.
http://i1117.photobucket.com/albums/...hone%20075.jpg
http://i1117.photobucket.com/albums/...hone%20076.jpg
http://i1117.photobucket.com/albums/...hone%20079.jpg
http://i1117.photobucket.com/albums/...hone%20080.jpg
Cheers mate, just bought one.
Has anyone else ran into this issue? The AEM 30-0333 logs correctly with my laptop connected, but not with just the MPVI Pro Interface logging (without laptop). I'm logging the channel "WB EQ Ratio 1 (SAE)" as well. Thoughts anyone?
*edit for more info*
The AEM 30-0333 works through the canbus, and connects directly thorough the OBD-II port. Odd that it works when laptop is connected, but not when trying to log using just the interface.
I've never tried logging it with just the interface. I assume you mean via standalone logging?
Updates? Solution?
Update from support: This is a known issue, there is no ETA on a fix for this issue at this time..
Was hoping the 3.7 beta would have the fix
