2011 Caprice E38
My tune is scaled for my injectors, I assume this is why my average MPG and range are about double what I would expect. Is there any way to change this to display correctly? Obviously not a big deal, just curious.
2011 Caprice E38
yes its under "fuel density" in the "fuel" "general" section, just scale that number to the same scale u change the tune for the injectors, if u doubled your stoich then half this number is how mine worked but if u have an idea of what it should be see if its correct after the change
Thank you.
I generated this calculator for establishing the fuel density value. Never got to run a lot of samples so not entirely sure on its accuracy. Give it a try and let me know how it works. May need some tweaking based on my assumption and your findings.
Ed M
