try to rescale your ETC rpm axis (normalizer)
Thanks Sultan, I did that and it stills limiting rpm to 2000
Eric, I am working on getting a log for you . For some reason i keep getting a Initalization error every time i try to log the Mustang with the 2.24 scaner
I'm having the same issue on a 2012 F150 5.0L
I can provide logs. The 2.24 scanner seems limited, and ID's it as a Silverado, however I assume it will still scan correctly? Are the parameters the same?
Buy a JPC Line Lock kit, I figured out how to make it work on these cars back in 2010. A few have copied it since. We sell it as a complete kit so you can sit there and burn the tires off all day lol
Ok if you look under engine torque management there are three limiter tables fuel - fuel and spark - spark only there you will find the answer to the BOA 2000 rpm limiter
What are the desired changes to those tables?
Thats the tables to work!!! ...i finally can do a decent burnout thanks a lot for your tips
Your welcome just takes a little looking with all the hints i gave !!!!! I spent a lot of time on this thank god that part is over. I could not tell all as i do not make money doing this and most tuners will not help you out whitch i can under stand if that is how they make there living but they should spent a little more time on R&D work.
What did you end up changing?
Also curious one this as well.
Read post # 27 and you will find the answer
lol, I asked what changes were made over a year ago still never got a concrete answer, and now I don't even remember why I asked.
Hi eric i have same issue can u help me with or anybody i have mustang v6 2014 when i start to do a burn out my rpm staying on 2000 can u help me with plzz
