Map sensor reading too high
I'm helping a friend get his 91 z28 running with a ls1 ECU, 1bar SD OS. It has the coil pack conversion on his tpi motor. It idles and runs okay. I'm concerned with some backfiring through the exhaust.
Are you/lt1 map sensors comparable with ls1 map sensors? Offsets any different? At idle he's around 40-50kpa but at cruise with hardly any throttle he is at 80-90kpa.
I feel this is way too high. We tried a different map sensor with same results. Both are confirmed 1bar map sensors (039).
Any suggestions?
It's making it hard to know if it's running right . With wideband and be table tuning, the AFR is good but it's still running rough and backfiring randomly.
