Anyone getting this? I started a ticket on it Sunday with no response so far.
Attachment 71330
Josh
Attachment 71330
Josh
What version of software are you using?
3.6. Somebody did respond and posted 3.7 in my profile. Will try that tonight or tomorrow morning.
Hi Erick I have a customer with a 14 Ram1500 he wanted to make some changes to the transmission for shifting. He came in after I downloaded the 3.6 version, I did a read engine and transmission, I made the changes and licensed to save the changes. (two Credits) the customer dropped the truck off and I went to upload the tune (clicked on the write to vehicle and it gave me the need to license vehicle and it is showing it now needs four credits. I'm not sure if I'm doing something wrong any help would be appreciated.
It takes 2 credits for PCM and 4 credits for trans. so you probably licensed the PCM but did a PCM/TCM read. Technically you could have only tuned trans, but in some cases you need into the PCM to make changes that affect trans (TQM, rev limiters and so on). 6 credits total for them 8-speed equipped Dodges! Mmmmmhhmmm
Any updates here? I haven't been able to write the Trans for a week now.
3.7 Beta, licensed the PCM and TCM. Diablosport Unlocked PCM.
I will give that a try thanks for the information.
I've had cars that didn't like flashing both at once, the TCM's are a little picky and like a full power down before a flash, so I just flash PCM (select "Do not write to TCM"), power down, then select "Do not write" to PCM and flash TCM by itself. Maybe give that a try.
tried a combo of different things including this.. waited for off light to turn off and tried only writing tcm many times.
Seems odd, does the trans work ok? Have written to it before correct? Any errors pop up?
that is normal it is 2 credits for the PCM and 4 for the TCM
