I have something going on with my lambda error equation that shows a result of something around 1400-1500% error. Can anybody help me figure out what is wrong here? I have attached some screen shots and my scanner config.
actually that was the log that I posted. Attached is the config.
your aux.20003 is the wide band reading in afr not in lambda . so your pid for lambda error is 100 x afr minus lambda devided by lambda. that wont work.need a pid for lambda---wb/stoich.
ok. i see why that wasn't working now. does the set up in the pictures below look correct now?
no.you still don't have the wb reading in lambda.see this thread---http://www.hptuners.com/forum/showthread.php?t=26134&highlight=plx+lambda . or use the search function.
