2 Attachment(s)
Stroked LS2 SDOL tune T56 car E40 pcm - bog on hard shift at redline log attached
Hi all.
I have an inconsistent lean bog on hard shifts since I switched over to SD OL.
If I shift 2-3 or 3-4 hard up near red line I dump the clutch back out and mash the gas pedal and it feels like I mucked up the gear change. It feels like the gas pedal does nothing and then the car jumps back to life. It is not a long delay, but enough that feels like my feet were totally out of sync on the gear change.
Other times I bang the gear and it hits hard and keeps pulling.
I managed to FINALLY catch this on a log. It appears there is a significant delay for the injectors to begin spraying fuel again despite the gas pedal going to WOT, the throttle body going to WOT, and MAP showing WOT pressures.
I'm pretty unsure where to go from here. VE isn't perfect and I'm running a bit fat, but nothing is too awful I don't think.
The bog happens at 11:07 in the attached log.
Attachment 65416Attachment 65417
