Hey guys, how are you locking the convertor and holding 4th gear for testing? i thought there was a switch in the scanner, but i only see a crank relearn and kam reset,
thanks, any help would be appreciated.
ok, i found the gear enable switch in the editor. any word if this also locks the convertor or does that have to be commanded via MPH in 4th?
This is how I have done it in the past with Auto's, just set up the upshift speed and RPM to something not attainable, also to be safe do the same for the downshift, something like 5mph would be fine. Just be sure to flash the car with a a file that doesn't have these changes done afterwards.
