Oil Temp in VE Commodore
Am i able to change this parameter in HP Tuners as described in the attached post from Aust. LS1 and Holden forums.
I am changing the SIC in a VE as per the post.
http://www.ls1.com.au/forum/showthre...t=atari&page=2
This would be very helpful as i already own a HP Tuners interface etc. I don't really want to have to invest or use another system to make this change.
Thanks in advance
we're in the process of adding this and couple of other things now:
- Oil Pressure Type (switch or sensor)
- Oil Pressure Calculated (enable/disable)
- Oil Temp Config
Oil Temp Config lets you set how the Oil Temp is calculated and displayed the options are:
- Calc ECM (oil temp is calculated from ECT and a few other things)
- Calc ECM & Disp Sens (ECM uses calulated oil temp but gauge uses sensor measurement)
- Sens ECM (ECM uses sensor measurement if no sensor faults exist)
- Sens ECM & Disp (ECM & gauge use sensor mesaurement if no faults exist)
I've also added the Oil Temp Sensed PID to the scanner (and renamed the existing Oil Temp to Oil Temp Calc).
Should be in beta in a week or two.
Chris...
