peak power calculator
hi
with my friend gmc sierra 15 ... supercharger and cam
and tuned by shop ...
in the last time .. there problem in the car and he lost about 100+hp in the dyno
.. when we check i found timing in idle -15 / -16 ! + also all injector not work properly
i ask some guys and he say ( you must re-calculator torque model )
what you think ! and how i can re-calculator torque model
So one pull to the next and you just lost 100hp and it went to idling funky? Am I understanding this correctly? Really sounds like you blew a vacuum plug off of the blower somewhere and now you have a major vacuum leak - that's if it just started one pull to the next...
If it's been doing this from the install time, then yes - it's a DI engine correct? - So needs a complete retune - more so due to the cam than anything else... Even though you should be able to adjust things in a lot closer without even touching the torque model...
This also might need to be in the gen 5 section for further assistance ;)
