Which OS / Computer to use for 3 bar setup
I have an 87 GN motor (3.8 turbo V6) that I am going to do some experimenting on.
I have all the factory harness and computer, but the factory computer is very limited. I could convert it over the XFI, but that is like $2K. So I figured I'd see if I could get it to run on a newer GM computer. I'm just wondering what the best option is in the v6 arena to use as a starting point. I knew in the past the v6 options were quite limited.
I understand that I have to have a new harness and computer, convert over the crank sensor, cam sensor, etc... I can do all that. But before I go modifying anything I need to figure out what is the best starting point from a year/computer/harness/sensor standpoint.
If there aren't any workable v6 options my question would be if you can change the number of cylinders and firing order in a V8 OS and use it as there is a lot more support on the v8 side.
