Originally Posted by
RWTD
Siemens (Continental) 60# Injectors
(data below is for use in HPT format)
Flow Rate Low: 63.1872
Flow Rate High: 60.26760
Breakpoint: 0.0000336300
Note: You will need the latest beta of HPT in order to input this value, otherwise 2.22x will round up the data in this parameter, and you do NOT want this to happen!
PW Minimum: 0.94985963
Note: Ford Racing's data will have you use 1.391. HPT's 2.23 Beta is currently only allowing for a max of 1.0. I've a bug report to HPT to fix this. HOWEVER, many of us tuners have found that 0.94985963 works better for these injectors you're using anyway, and that is why I listed such above.
