3400 LA1 PCM w/ 282 Getrag
So, I just got my motor running with a VATS delete. I did some research on what to do about having a manual transmission with an automatic PCM, and all I found was 2 options.
Copy tune from a manual equipped car
or
Delete A4 codes and raise Idle RPM
Since the 3400 (and many of the 60* V6 motors) did not come with a manual transmission, my only true option was the latter, which has the car running fine at idle and revving it a bit seems fine. I'm waiting for the exhaust to be done, then I will be tuning the motor to the new exhaust/intake. Maybe I am just making a bigger deal than I need to, but I feel like that is not enough to make the car run fine while in gear.
Main problems I possibly see:
No Torque Converter
Accell and Decel
Clutch Engage
Load between gears
More I look at it, more it seems I just need to re-tune the motor without the torque converter and there won't be any problems afterwards. Should I just make all gear tables mimic each other? What about when I depress the clutch? Will this cause the motor to almost stall? I moved the lowest Idle to 800rpm for now, am going to re-tune my Idle and whatnot, but trying to figure out the transmission stuff first so my tune isn't all funky. I assume the car just needs to see the vss and it will use the accel and decel tables to help retard or advance timing? There is one pcm I think I can use as a reference, the G6 3900 has a manual transmission. I downloaded a stock tune from the repository and plan on looking into it.
I plan on looking more into how to tune, the only tuning I've really looked in depth at yet is the Idle, I figure take it one step at a time so I don't mess anything up.
Plan on figuring out:
Transmission behavior and how it is linked to engine tune (that's what this post is about)
Idle
MAP or MAF? (I've seen the word speed density thrown around, still need to read up about this and whether to tune for MAP or MAF)
Accel/Decel? (I am going to assume I need to change these tables due to my increased flow)
Any help would be appreciated, otherwise I will plan on figuring everything out myself like how I made my wiring harness, rebuilt/ported my motor, and made my own 180* equal length headers. (Thank God that motor runs and sounds great we will see how it holds up) The tuning is just something I can see myself messing up over and over or banging my head against a wall for 2 months, this is my daily, and ive already spent 6 months on this swap so I am trying to finish tuning it before the end of the month.
Here is a picture before I got it running:
https://scontent-sea1-1.xx.fbcdn.net...8d&oe=56AF7539
