sorry if I missed this. but are you able to flash the fscm now with this new update?
Is there no cylinder balance test?
There is not. The cylinder balance test was really only good at finding cylinders that weren't firing (wire/injector/plug/coil). All the test did was command a IAC position and then disable each injector one at a time.
If you think you have a cylinder that's not firing and aren't sure which one, you can command a IAC, and then disable/enable each injector one at a time. If the cylinder is firing well, the engine will stumble more when you disable the injector. If the cylinder isn't firing, there will be no change when you disable the injector.
What about the 2018's? I got a 5.3 6 speed try to read it and it only have the option to read the TCM no engine.
I wish HP tuners would focus on older diesels ecm. GM 96+ 6.5td , Ford 96+7.3TD and Dodge 98.5+ cummins vp44
All of those ecm are able to be tuned have a large customer base but not supported by hptunners. I dont think HPtuners understand how large of a market there missing out on.
It's my understanding that calibration support isn't necessarily the issue - the problem is the interface won't jive with the earlier ecms - I think they're still working on coming up with something, but don't know for sure on that one?
I am trying to change tire size using HP Tuners 3.6 software
but it seems like it missing Gear/tire calc Option?
can any one help me please
I am trying to change tire size and gear ratio using HP Tuners 3.6 software
What vehicle/computer?
Did you click the edit tab yet?
04 Pontiac GTO
Where can i find edit tap?
when i click on speedometer it shows me just calibration and limiter option
C'mon, you know like at the top of the screen in the left hand corner like always.
File, edit, compare, flash, tools, windows, help etc etc etc.
Oops!
Okay now i found it i didn't expect it hidden right there, thank you very much
I am running 3.6.26 and I don't have the VIN wizard. Is there something wrong with it?
:مرحبا:
good
Is there anyway to download this with Chrome OS?
