Originally Posted by
abc
I will look into the two tables/parameters you mentioned and likely run some tests.
I'm guessing the two tables you mentioned will answer some of these questions but is there a way to slow down the response rate of the STFT's? Basically as the NBO2's switch from lean to rich, rather than add 5% fuel in milliseconds, slow it way down and add that fuel over the course of a 1/2 second or so, then of course do the same for when it switches from rich to lean. I also assume with the info. you guys have provided, you have already explored this scenario and will tell me why or why not this may be an option. If the answer is in the tables you mentioned, then I guess if you read this before I get back to you, just tell me to go look at the tables.
Thanks again for your help.
