i recommend listing the hardware selection for each year as HPT will not recognize
Hi,
What about converting to E85? Is it sufficient to change stoichiometric AFR to be in the ball park?
for anyone that is trying to read 2014 infiniti q50 3.7
controller SH_7253_331
it kicks the fans on to read and stops mid way
all others read all the way and bad checksum and definition issue
Attachment 111059
find attached
after factory flash to this 2014 q60 3.7
i find that definitions are not labelled correctly maybe
like speed limit only in reverse
Attachment 112238
HPt abandonded nissan/infiniti?
support is not the best, but there is also issues i am finding with the other software. espcially VK56DI
Is there any update for the Knock parameters not found in the scanner and speed limiter not having an effect when changed ?
2020 370z controller SH_7059
