Originally Posted by
MikeOD
OK...your VE table is a complete disaster, your boost enrichment table is set to 1.00, so it's ignored...that means you're using PE only, on an engine with a turbo...I'd much prefer to use BE than PE on a turbo setup, since depending on gear, and throttle condition, boost can vary by RPM...you've also got the enrichment rate set low, bring that up to 1.0.
Also, this is a gen 3 PCM/operating system. Re-post this in the gen 3 section, you'll get more help. Gen 4 engines use different computers.
