Originally Posted by
evan.s@hptuners
I think you misunderstood, you can still leave the flex fuel mod switch as disabled, which won't enable flex fuel. In fact this is what you should do if you aren't running a flex kit or plan on using the mod. HOWEVER, if flex fuel is disabled, the Low Ethanol tables/scalar are the tables being referenced even when flex is disabled. I realize this is a bit confusing, which is why I'm migrating back to the OEM tables being used. For example, if you want to edit the cranking IPW, instead of editing Crank IPW 1-6 in Fuel -> General -> Startup, you would instead edit the Crank IPW 1-6 tables in Fuel -> Flex Fuel -> Low Ethanol Content (Leaving Flex Mode still as "Disabled"). The logic remains the same, it's just the table gets moved to a different location in the software. Editing the original OEM tables with custom features applied will make no changes
