Originally Posted by
edcmat-l1
I don't care who did it and when, that table set the way it is, is a quick and dirty way of keeping it from going into negative timing at idle. It is a sign the person who tuned it could not get it to idle properly, return to idle properly, have decent to normal idle quality, etc. If you want to know how well the rest of the tune is dialed in, put that table back to stock.
If you're familiar with GEN4 stuff, the condition you're describing is typical of BRAF being too high, throttle follower being goobered with by someone who doesn't know what they're doing, etc. It's an idle flare after a downshift. That being said, I can't tell you there's a silver bullet fix for it in this. It is most likely a combination of things all revolving around idle torque control.
All that being said if it came to me to fix this problem a bunch of it would need put back to stock and start by dialing in the VVE and VVT.
