I love to learn....please keep teaching :-)
You mentioned 3 TB tables. Obviously one is the Throttle Body Airflow table, what are the other two? Is it the small/large range under Desired Throttle?
I've seen Sonic airflow mentioned in other threads and how other software has the ability to log it. What exactly is that and if we could log that what information would it provide?
Here is the part I don't seem to be getting with everything. Like Hemituna I have found matching the 3 TB tables does not net the results that it seems they should. The bigger thing that I've found though, when running a bigger cam, or anything that generally requires more airflow at idle or higher idle, seems to react best to increasing the airflow values in the Throttle Body Airflow table and only that table. The part I struggle with is in theory this should cause the throttle body to run less throttle position. It does just the opposite in practice, at least in every situation I've encountered. Can anyone explain this?
It is because the idle control is torque- based and not airflow.
You play with the airflow numbers to get the torque correct and then it will control the idle nice.
Actually the whole PCM is torque-based and you are just using airflow etc to get the correct torque numbers.
They idle/drive amazingly well when all is aligned.
Definelty agree, if the time is spent getting the tables figured out it seems like they work great. The problem I have seen is I guess a lack of info. Like was stated earlier in this thread there are things we cannot log. So this turns into an issue of not having the proper data to actually make adjustments that are data backed. Now, experience in making adjustments and knowing how the car will react can be helpful, but I'm one that likes to be able to back up or prove that those changes are doing what I think they are doing, not just hacking or masking an issue.
So this brings up my point or what I guess I would really like to dive into with all of this. NOV and Wheel power tables, TQ management tuning, REQ TQ adjustments, DES Airflow....all of these things are crazy important in tuning these cars and really most any newer car. So specifically with the HEMI's has anyone really figured out what to be logging or how to log all of the proper info to understand exactly what is going on during idle and part throttle to be able to properly setup these areas? I know for me, at this point it is still a bit of an educated guessing game, and personally I hate doing it that way.
For example on a car I have been tuning recently, it shows a commanded tq of 0 until the car is in gear, and without looking back at the logs, possibly until it is actually moving. So that being the case, and this being a tq based idle system, it is not really possible to use that info for making adjustments. At least not any way I can figure. Then when you get into airflow it is, like stated earlier, sonic airflow, which is not able to be logged, so the data we have is basically not valid for making calculated adjustments. At this point it is more we raise and lower until desired and actual airflow values come inline. That is not a big deal, but a much better way would be to know exactly how much movement we need in our tables based on data in the logs. Percentages may be able to be used in some sitations, but I feel like there are too many calculations going on in the background for that to actually work everytime.
You do realise that these numbers (airflow/tq) are manufactured right??
Its just a way of quantifying things so things can be made to work together.
The original calibration probably would be close to correct however when you make changes to the engine that all goes out the window.
You just have to play with the numbers till everything is happy.....
It can all work sweetly whether you have 500hp or 1000hp, the PCM is none the wiser.
Realize, yes, though I want there to be a better way to tune these idle and part throttle areas for a smooth transition. Everything around the throttle movements is all an educated guess, and to me that just seems like a bad way of doing things. It's not really accurate, and it is horribly inefficient. I just keep researching hoping to find a better way, until then I'll keep doing the same thing you have done, make adjustments, drive, and repeat until I'm happy with the results.
If you cut, say...20% out of everything above .5 volts in the Throttle Body Airflow table like you're saying, do you need to rescale the Desired Throttle (Large/Small) to match the new values? In my factory tune, the values in the Large/Small Desired Throttle tables are the inverse of the Throttle Body Airflow table.
Good info, BTW! Keep it coming... I'm fighting the setup in my signature (the 392 stroker), trying to get it perfect.
Dam this is great info.
Thanks to all involved!
Now, does anyone have an opinion on how to tweak these numbers for a dual Hellcat TB, progressive linkage setup?
That's what I have on a 6-71 above my 398 6.1 based Hemi.
The second TB is manually operated off of a progressive linkage and the primary is DBW.
The secondary starts opening at about 18% of the primary and is linear to 100%
I'd love to hear some thoughts on this.
Attachment 74866
https://youtu.be/qynyDH0_YAs
BAD AZZ!!! I love it! I'd sure love to play with that tune too! I'm betting it'll be fairly easy to dial in. It took a boatload of tunes to get mine right however it was done way back when the tuning was still a big guessing game for Mopar and more "hackware" than anything with DS. With the hat like I have its more like a BIG throttle body so it took some work to get it happy. Only having a little over 8" of vacuum at idle made it exponentially harder. My best friend begged me to go with the Mad Max theme like you have but I liked the bird catcher look better. It's really cool to see someone do it. Started with a BDS 6-71 and then upgraded to a Whipple 8.3 liter.
Are you tuning it yourself? I made a quick video of my setup and you can see how we just used the throttle body to work a bell crank for the hat. Sorry my video skills are lacking to say the least but it wasn't made for the public just figured I'd share https://youtu.be/h8TuZncJH-8
That's one of the builds that inspired me to go ahead with the 6-71 build. Southern Hot Rods I believe.
Thanks for paving the way. I really wanted to make sure to have an air filter though since it was to be my daily driver for a while.
I'll be doing the tuning soon, but Johan (Diablotoona) has done tunes for me for a few years. The TB setup was always a trick.
I first used an electric control by Ozmo Engineering that would mimic the primary TB with the secondary.
The huge rush of air off idle really caused some problems. Changing to this progressive really smoothed everything out as far as drivability.
I'm really curious as to the TB control settings in HPT and if they have "progressive" control built into them, if I'm doubling that up by having my mechanical setup being progressive as well.
More trial & error I suppose. :)
The trial and error is the fun part lol. Yes Southern Hotrod was instrumental in making it happen. We did it when they said it "couldn't be done" which was very motivating. Makes me happy to have inspired someone and glad to see you pick the torch up and carry it even further.
I've had lots of compliments and criticisms and its definitely a love it or hate it type thing. I've enjoyed every minute of the build and have no regrets other than not using it as a marketing tool because it always got serious attention just because it was different. If you ever need anything just hit me up. And please keep us posted on the progress :-) It'd be really cool to have them together in a photo shoot ;-)
yall arent referring to the shop in kenner are yall?
That would be the one.
Southern Hotrod LLC
I have experimented with these airflow tables alot today in hopes of not having to modify the throttle tables and I cannot find a good solution(car is 2009 challenger with vortech and cam). There seems to be something that is unable to be changed to tuning in the HP software, something in the background possibly.
the desired airflow table did help a laggy throttle feel, but i wish there was some better explanation out there as to why and how it truly works. at the moment what ive read here and have tried is merely just throwing darts at it.
The second thing I have experienced is that even when all torque ESP management (fso, etc, spark) reduction methods are shut off the vehicle can still show signs of the the ignition being retarded and the throttles not being allowed to open, i am curious if there's other strategies that we can't have access to that are there.
its a pity because you can see signs of the car wanting to accelerate and take off like any 600hp car. but its all muddied up by the ecu. feels like mush, when it should be crisp and snappy.
screen shots of the throttle blade being held back. (yes i experimented massively with the voltage threshold hold for WOT pedal) it does nothing but move the stair step ledge to a different spot.
Airflow is secondary....only used to make the tq calcs because that is what you do when you step on the gas ...you make a tq request..
The pedal tables, and the flywheel table are using the airflow tables to give you x TB opening to make x tq.
If all that exceeds a tq or airflow number, the PCM will limit tq with TB opening and sometimes timing.
Those limiting numbers at P/T are low....really low factory numbers! They only allow the (quite large) TB to open as much as the stock engine needs.
We need to fudge the numbers so we get more TB opening for same airflow/tq numbers to stay under all the limits that we can't see yet (ever?)
So use very small airflow numbers above idle. If you find throttle is being limited at PT, reduce airflows by 20%, if that doesn't fix it try another 20.
I now make my desired airflow and TB max's about the same as the original airflow limits... way, way small, like 350g/s on the 6.4's
Once you are getting closer, you can then play with flywheel power to dial it all in at various rpm.
You can get em responsive and predictable just like a cable when done right, but only if you work with the system and try not to fight it.
