I cannot find a manual tune for a G8 or Commodore with the same 12624402 OS as mine so I can do a segment swap for my T56 Magnum swap. Can anyone help me out? Thanks
Don't think the segment swap wouldn't work on that vehicle. Probably going to have to start with a manual calibration file so all segments are correct.
Care to elaborate on why it wouldn't work? Is it because there aren't any manual trans cars with that OS to do a segment swap with?
Which segments would you swap, since there is no TCM to put the segments into and no TCM segments in a manual trans tune file to pull segments from?
You need to grab the VIN from a manual-equipped car, plug that VIN into GM SPS, and program the ECM.
The segment swapper is for computers where the PCM/TCM are together, like the P01 and P59 computer for example.
Your G8 uses a E38 with a separate TCM controller. I think you either need to start with a manual OS on the engine side or you may be able to just change the ECM trans type from automatic to manual and start tuning it.
I'll have a look mate on my other laptop is that 2009 etc...You can do it , have you had your other modules/bcm /cluster as a example programmed to a manual also
Here mate try this Attachment 119531
Thanks for the file! unfortunately when I go to open the file it says "Unable to open file... This file is a part of a Remote Tuning network that i am not a part of."
What version are you running
Looks like 4.8.7
Should I download the most recent version for it to work?
