2 Attachment(s)
AEM 30-0333 - OBD / CAN connection on Scanner 3.4
Would anyone have some tips for connecting the AEM 30-0333 through the OBD / CAN port and logging in the scanner? Scanner version is 3.4.xx I have the wideband installed and hooked up the pass-through cable to the OBD port, but I'm not getting any wideband in the scanner. Everything else is coming through the OBD port just fine. In the scanner, I am using the AEM - AFR channel. Is this correct? Most of the instructions I found regarding the AEM going through the OBD / CAN port were for the 30-0300 and beta scanner s/w. In these instructions there was a different PID channel called WB EQ Ratio 1 (SAE).... I assumed that no longer exists because I don't see that anywhere! When I start the log, the AEM - AFR channel disappears.
Anyway, here is what I see in the scanner....
Attachment 69133
Can anyone confirm the DEFAULT AEM settings are proper for plug-and-play?
Attachment 69134
Vehicle - 2007 Silverado 1500 (NNBS) - 6.0L - E38 (I'm not even 100% this truck is CAN-bus, vs pre-CAN, but I assume so because it's kind of a transition year to Gen IV). I saw some stuff about a termination resistor with the 30-0300 and pre-CAN vehicles, but I'm not sure this applies for the newer AEM factory cable.
Any ideas?
Thanks for the help!
