1 Attachment(s)
GMPP LS376-525 crate package high idle
I have searched and found quite a few threads asking for help with the same problem, but nobody posts about what fixed it...
A friend of a friend asked me to look at this tune file. He has put two of these GMPP crate packages into older hotrods. They both do the exact same thing. They idle at 950-975, and they both run and drive just fine. But he wants the idle to be closer to 750 or 800.
In the tune file, the commanded idle is 850, minimum idle is 825. I lowered the RAF tables by 20%, no change in idle. I lowered the RAF tables by 50%, no change in idle. Then I zero'd out the RAF tables, and the thing still started up and idled at 950. I smoke tested for vacuum leaks, none found. PCV system is correct. I don't get it.
Are these things hard-coded from GM? I'm using version 2.23, here's the file.
