1 Attachment(s)
The software in your control module is outdated and can not be used....
With select ECMs & TCMs, outdated versions of software that are on the module can not be supported. When attempting to tune your vehicle, some may receive this message:
"The software in your control module is outdated and can not be used. You are provided with the latest stock software. If you choose to use this file, any existing changes you may have had to your old software will be overwritten"
Attachment 53990
After you click "Ok" to this message, VCM Editor will automatically load the latest supported compatible version of your software for you to use. You can then make your changes to this file. Once you're ready to write your ECM or TCM, this new tuned file/software version will overwrite the current version of software loaded on the module. Because it is overwriting the current software, any changes you had previously made to the ECM/TCM (i.e. via other devices) will be overwritten.
Thanks!
:cheers:
