We finish installling a turbo to a 2010 silverado, Its a 76mm on a stock 5.3
Heres my file want to be sure if its on pure MAF, just waiting on the injectors and the scanner that i did with the file stb1 n 2 are way off.
I dont get why my stb1 and 2 are still on...
It's in MAF mode. You still have fuel trims because your O2 readiness ECT isn't set correctly. Set that to 400 or something unachievable.
FWIW, I don't like setting things to zero (your dynamic airflow). I'd rather there be something in there, like 200 or something.
O2 readiness ECT its at -40, change it up to 400?
Heres the update file.
My stb1 and 2 were way off because one of the injectors was not sitting down right, about to log it see what it does still eaiting if my file is good to go...
I upload the file and took off the bank 2 sensor 1 off of my down pipe to install the wideband, now i getting codes that are from the sensor i took off is this normal till i install it back?
p0050
p0154
po155
Thanks...
