Cold Starts are totally screwed.
Hey guys. I don't really even know where to begin. What I'm giving you is my 50% scaled tune out of my Silverado. It's MAF only, big cam, ID1000 injectors, Big Kenne Bell supercharger, LS3 TB, etc. Displacement is 415 C.I.
I recently got Chris's throttle body relearn procedure added to the scanner so that I could reset the ECM's previously learned airflow values to make the truck idle as commanded. However as soon as I did that procedure and set my base running airflow tables correctly for warm idle the cold starts went totally AWAL. Dunno what I've done or why it's doing this but here's a log and my tune. I've never seen this before but hopefully you guys have.
It starts, runs for about 1-2 seconds perfectly, then the Injector duty cycle goes crazy and it floods the truck with fuel, essentially killing it. It takes 5 more seconds of cranking to get it to clear, cough and start, then it does it again! But the warm starts are fantastic! WTF?
Thanks for looking at this, any help and/or suggestions would be greatly appreciated.
-Robbie.
