Boosted Ls1 240sx (Not starting)
Hi guys, Trying to get this ls1 started, In the scanner under as far as codes go it gets crankshaft re-learn, now Ive seached and searched and found that its in bi-di controls but hw do you get to those settings, here's my setup:
-ls1 shortblock (camaro)
- 317 heads w/ comp 918's
- MLS and arp head studs
- aftermarket fuel rails
- 120lbs injectors (lucas)
- aem injector driver
- 76mm turbo
- tial mvs
- ati dampner pulley
- 2004 GTO 5.7l pcm
- ls1 corvette harnes pinned to gto.
- camaro TB
- th350 Built by JW.
The car cranks but no turn on, Im by myself so I cant check for spark, fuels there but dont know if injectors are firing.
Heres my tune I have hp tuners pro w/ mpvi controller and 3bar map sensor.
Any help would be greatly appriciated. Also I have found my flow rate calculator, so I still havent put that in yet.
