Can additional sensors be added to a PCM?
Here's the skinny on my setup...
1997 Pontiac Bonneville, running a 2007 L26 w/L36 intake, 2006 Grand Prix 4T65e w/3.29 HD conversion, controlled with a 2005 Impala PCM that's been flashed with a 2003 GP file (because it won't run with the Impala file due to it needing to see the BCM...what a waste of credits that was). It is now being converted to returnless fuel injection, and new wiring run in case I want to top swap it in the future.
Now then, on with the questions I have for this particular build...
1) I'd like to run a fuel pressure monitor that the PCM can see. Is it possible? What pin cavaties would I use if it were possible?
2) In an L36 file, can the supercharger boost solenoid be enabled, or do I have to burn two more credits for the L67 file, just to be able to get this to work?
3) Thinking about deleting the fuel tank pressure sensor...could I use this 5V signal for wideband o2 instead? If question #1 isn't possible, I should be able to use this circuit to do what I want so long as the sensor I put on the rail is a 5V, correct? And if so, how would I get the signal to reflect psi on the scanner?
Thanks in advance...
