how do I do this, everytime I try it just said it's not supported or something like that. I have a wideband and hpt pro.
you have to log commanded afr and wide band afr in the table display.
and afr error.
Whenever you get unsupported parameters you're not logging what you need in the table in order to display the histo. So if you were tryint to plot AFR error against the MAF table you would need to log Commanded AFR, Wideband AFR and MAF Frequency. To plot AFR error against the VE table you'd need to be logging Commanded AFR, Wideband AFR, RPM and MAP.
:) I figured this out already, but if I was still clueless about it Mr. winters explained it well.
Back from the dead. I need to plot afr error. I have map,rpm,actaul wideband in the primary table. How do i get command afr in there?
Search for it. Its been so long I forget if afr error % is its own PID or if you need to make a custom one that does some math to get it.
