My E50 tune is a little older, it will not let me compare to yours. Have your entire last row of driver demand 600 ft lbs. Use LSPI high to limit boost. When you hit that it will show popcorn in the log. Put all LSPI back to stock. I attached a picture of mine that got me 230 KPA across the rpm range, Put this for LSPI high. Yours is way too high. Nominal needs to be stock. This will lower boost if you have knock and bad fuel. Raise your cylinder pressure limit, it will take more timing. You will need to get that FMEM out of the way too.
Attachment 144821
