Simos18.1/6 - Wastegate Patch Issue
Hey there,
I am running a 5G0906259D_0002 (Simos18.1/18.6) in my 2016 A3.
Applied the wastegate OS patch so that it is no longer using the FF logic but desired PUT / RPM. However the RPM axis of the new FF table is completely out of whack. Also confirmed the same with a 5G0906259L_0002 file with the patch applied.
Any chance that anyone has used the patch before? Did you just edit the axis values to make actual sense, or is there an underlying scale factor HPT applied to the axis?
(I haven't tried flashing or even editing the map values yet)
https://i.ibb.co/SBSZSb8/Screenshot-...-20-071250.png
