Hello, is there a write up on setting up a aem 30-0301 for a p01 system in the scanner. Also would this be the best one for the aem models to use for my set up?
Recently hooked up the AEM 30-0301 fuel pressure gauge to a prolink but HPtuners is reading about half what is on the digital display (i.e. 26.8 psi vs 52 psi). I'm using the transform model option AEM (PN 30-2130-100) 100 PSIg. Any advice for this noob? Do I just create a custom transform so it matches the digital display?
Have you checked the voltage output of the gauge to see if the math works?
