Is anyone on here running Holley Injectors?
Been going through different injectors and flowing them, i really have no idea how to calculate the actual Data to put into editor. I have gone through Bosch 210's Deka 80's Decapped shortys, Decapped Flex injectors, The best ones i have had are the decapped Flex injectors, they flowed like 85-90 LB/HR. Thinking about switching to some Holley Injectors they use the ev6/ev14 connectors I think. My harness uses the EV1 plugs but i also have the adapters that Make it work with EV14 Injectors. I found the Holley injectors on Summit 100LB $400 for a set of 8 and 220 LB for about $700. Makes more sense to start with injectors that are proven with valid Data, there are a lot of junk injectors out there.
