1 Attachment(s)
1.4T - 12V source for ethanol content sensor
Hi,
I'm adding an ethanol content sensor to my 2017 Opel Corsa with the GM 1.4T engine and E78 ECU.
I'm looking for advices as to where would be the best place to get a +12V feed for the sensor. I've made the connections to the ECU, checked and got +5V with key ignition so that part is done with.
I looked online and couldn't find any helpful infos for my car, I however found a guide from ZZP for fitting the sensor on a Chevrolet Sonic.
Since the Corsa and the Sonic shares a lot of parts I gave it a try and installed my 12V wire into the light grey connector in the engine fuse box but no luck. I got 0V between this wire and the battery negative terminal so I guess my car is wired differently.
Attached is a picture of the connector and the location where I put my power wire. Thanks for the help!
Attachment 126593
