Ls1 to LS2 swap...camshaft position sensor code
Did a swap and used the Katech harness to adapt the sensor. It is now throwing the P0343 code. This is a new sensor, so I pretty sure that isn't it. The car is now real erratic with starting...sometimes it doesn't at all...other times, it fires right off. It has something to do with the timing. At about 3k, it pulls ALOT of timing out. It will have a total of 7-9* at times.
Is there something in the PCM that needs to be changed for the LS2? Bad sensor?
Scott
