4 Attachment(s)
Bobcat UV34 Unexpected Speed Limit vs Gear Behavior
We are working with a MY2023 Bobcat UV34XL (Polaris engine and controls) and are attempting to increase the vehicle speed limiter without success.
We've increased the "speed limit vs gear" [ECM] 6845 values, however the vehicle will begin closing the throttle plate anything above 25mph even with accelerator pedal position at 100%. A log file of this behavior is attached. See Bobcat TD6.hpl
Reducing the speed limit vs gear values below factory works as expected and the vehicles top speed is limited to the values that we input. We just cant get above 25mph when the values are set well beyond that.
We also adjusted Torque Management values. These appear to be functioning as expected until the rogue vehicle speed limit is met and the throttle begins to close.
I've attached the factory Bobcat/Polaris calibration, a modified calibration, and log file of the behavior we are experiencing.
We were also unable to find lambda as an available logging channel within the VCM Scanner. Do these vehicles not have factory wideband lambda sensors?
HPT support was unable to assist and suggested that the issues lies within the calibration. Any help would be greatly appreciated.
UPDATE: This has been resolved. We were using the latest stable release of VCM editor. Using the BETA release there were additional parameters available. Specifically "Farm Mode".
Thank you!
Tony Reiners
