Drilling of a 1/8" hole in electronic throttle blade
As the title says, my engine which is a cammed and blown Ly6 stroker and has an electronic throttle and an E40 ecm. We have idle pretty good now after a lot of adjusting RAF and timing. It has been suggested by a Pro tuner that we drill a hole in the throttle blade to get that percentage at idle back to around 18% instead of 24% like it is atm. This he says will give better control at idle. Can anyone here comment on their experience with this type of modification?
The cam shaft size is 226/[email protected]" .600 lift and 114Lsa if that helps. We have the idle pretty well nailed down but it does do a little hunt now and again under certain loads, but idle is basicly very good. I am running a fully manual T400 so the ecm does not know when it is in gear.
Any comments are greatly appreciated.
