Questioning my 02 sensors
I am not sure if the 02 sensors are the issue but if I let the car sit and run it will turn off pretty quick. These are a cheap pair of 02 sensors i think i bought from ebay for like $15 or something. It's kind of hard to get a log because it shuts off on me if i let it try to idle. the driver side bank reads signifficantly lower than the passenger side in the scanner. Also installed flex fuel sensor and Enabled Flex in my Tune. If I tweak my Injector flow or VE a tiny bit either way it will go rich or go lean at idle. Does not really idle, its a bit high. 3.3 Bar, Deka 80's, SS2 Cam , 5.3, Flex and T4 76mm.
