Pretty sure I wiped everything out but missing something
its trans tq management.
log shows less torque than your max allowed in engine tm vs gear.
I would try disabling fast torque exit and max torque values
max out all max torque vs gear under torque limit vs RPM
mas out trans input torque
ideas?
Torque management, general, traction control, max torque is set to 400 ft lbs. Try raising that?
max out traction control torque values.
max out max torque values for axles and prop shaft below trans input/output.
appears its happening in kickdown. if that doesn't work must be something in the background u cant see send files to HP support
or maybe some indepth trans data like shaft speeds, torques and slips may help if possible to log
Try this and it'll solved AM sure , GO TO YOUR Trans TQ Management , RETURN THE ABUSE MODE TO STOCK & HERE YOU GO :cool:
GO TO YOUR PE TABLE & ZERO THE DELAY ...
GO TO ENGINE DTC & RISE ALL OF MISFIRE TABLES, ITS LOOKS THAT YOUR RUN A TQ CONVERTER & THAT WELL HELPS THO ..
I think it got it 99% squared up if this is the swap car Im thinking about. Email me [email protected]
Not sure which car you might be thinking about, but I found the fix, if you are interested.
https://forum.hptuners.com/showthrea...l=1#post434344
