Hi,
Wasnt sure were to post but would it be possible to add a "save as" shortcut. We have "save" (ctrl S) but "save as" would be very handy :)
cheers.
Hi,
cheers.
there should be a "save as" in the top left scroll down menu under "file"
I agree with FRASHD. I can't tell you how many times I've accidentally overwritten my previous config because the scanner has a shortcut button for save as but the editor only has save. I would rather the default shortcut be save as then be forced to go to file save to overwrite the current file. Or at a minimum a dummy popup that tells you the previous file is about to be overwritten.
At least the scanner and editor being consistent at a minimum would be nice no matter the save vs. save as debate outcome.
VCM editor has full binary history.
If you save over a file, view it's history and you can recover it from the previous save point.
A short cut like CTRL T would work great
