Temporary Wideband install question
I have the AEM 30-0334 x series wideband. I've done narrowband tuning and now am going to temp install the wideband 02 sensor replacing one of my narrowband sensors. My question is since i will then be adjusting based on this sensor...what happens when i revert back and install the narrowband sensor. Since the ecu will then be taking readings from the narrowband and making fueling adjustments accordingly, won't that nulify anything done with the settings done with the temp wideband install. I must be missing something here, but i don't see how a temp use of a wideband would work when reverting back to the narrowband. Just a bit perplexed.
